Discuss Toilet cistern identification? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
macka09
hey guys.
A friend of mine has an old outside low level toilet and I’m wondering whether the cistern May contain asbestos. I’ve added a Picture of it to see if it helps. Cheers
If it’s being removed then it needs to be double bagged and labelled it contains asbestos. Think you may need a license to transport it as well?
It most certainly does contain asbestos. All the old style black cisterns and toilet seats were made with asbestos. Very low risk as the fibres are too well bonded to cause any concern. But will still need disposing of properly if being removed.
bakelite so yes tbh i dont think you will break it taking it off the wall tough of old boots
You might find your local council
tip will take it if it's bagged up
Our local used to take any so long as it was double bagged. They changed it a few years ago now where you can still take it but have to apply for the bags specifically from the council and there's a 20kg limit. Any more costs you an arm and a leg. Ridiculous how the government knew it was dangerous but still insisted on using it in just about every construction product, simply because it's cheap and amazingly versatile. But then charge us stupid amounts money to dispose of it.
easier to find a local ab firm i know ours locally and they let us dump a bag or two in there approved site skip if any more its normally beer money
Reply to Toilet cistern identification? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hey Guys I’ve noticed this weekend that my en-suite toilet pan water level is seeming to regress after an hour. Toilet flushes as normal and...
Hello! I was checking something in the toilet cistern. I flushed, but holding the float ball, so the cistern wouldn't be filled. With a very low...
I wonder if anyone is able to help with advice on this. We have fitted a new toilet and 6 litre cistern .. it flushes .. but not as efficiently as...
2K
Hi, It may be coincidence but not long after getting oil fired central heating fitted to older ex-council property (fireplace and necessary...
SaintSinner
Hello all, We have a small bathroom, which currently has the toilet on the outside wall, and the sink on the inside wall. What are the...
2K
