Discuss Tightness test lpg system? in the Gas Engineers Forum area at PlumbersForums.net
Illuminate
illuminate
can somebody explain to me the reason why you have to do a tightness test then purge and then complete another tightness test on a lpg system rather than purging and then just doing one tightness test. How help will be much appreciated and so I get a better understanding. Thanks
I’m guessing new install with no gas in the pipework?
I believe it has to be done everytime a purge would be needed so yes on a new installation or when adjusting gas pipework or changing gas appliance (if I'm right but I'm not entirely sure) plus what would be the reason for doing it before and after?
It’s because air is lighter than lpg so if only testing with air it could mask a leak
You don’t know if the pipework is sound so could be leaking into a void eg open end etc and wouldn’t disperse as it’s heavier than air
Where all here to learn and help it’s one of them once explained it clicks
Reply to Tightness test lpg system? in the Gas Engineers Forum area at PlumbersForums.net
