Discuss ticking 3 port motorized valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
slapheadtwo
Hi, every now and again the motorized unit on my 3 port value ticks, about once a second. It sounds like the motor has turned the valve fully open, causes a micro switch to cut the motor and as soon as it starts to return under the spring the motor starts again.
It happens once or twice a week and normally when heating only is called. Occasional the rads fail to warm up and we switch the hot water on for 5 mins and then everything is OK. I replaced the 3 port valve about 5 years ago. Has it gone again or do you thing there is a wiring issue?
Thanks for any help.
Regards
Kevin
Reply to ticking 3 port motorized valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
