Discuss thoughts please no hot water in kitchen in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
moony
right
no hot in kitchen on a job ive been to today for 3 yrs.
other plumbers have been there all said its a big job and not willing to take it on prob due to new kitchen and haveing to take it out and put it back in again.
when opening the tap there is pressure but then nothing, there will be 3 units, sink to remove and refit and electric oven to remove and replace... to even get to look at pipework.
hot in bathroom - basin and bath both ok-
running off emersion in cylinder - cwsc above the cylinder on bottom floor flat...
i only had a quick look today have to qoute tmrw... was looking at a days work.
anyone come across a problem like this - was thinking airlock and poorly run pipework, but 3 years without hot in kitchen since it was fitted new ?
landlord has said do whatever it takes to put right.
could someone have fitted a nrv the wrong way round? daft i know but people do daft things some times or they could have shut local isolation and boxed it in if builder happened to do plumbing ?
could also see if u can get mains pressure up the hot tap in kitchen and out of the whb tap may be clear a blockage
Just a thought, if it's a mixer tap in kitchen give this a bash
get a 'plumbers mates bung' and put it over the mixer outlet, open the hot tap, then open the cold, allow the water to back fill up to cylinder, close the cold and retry a couple of times.
I had this in a vets surgery one time, I done the above 5/6 times repeatedly, It clear it and that was it, I never got called back to it
worth a bash mate
save u ripping kitchen out maybe if it works
cheers lads will try all this when i go to job, see if that works.... just with a few others having been to look at job it just made me think this has been tried but will give it a bash....
what are your thoughts on the pressure coming out of tap when first opened and also out of hot w/m valve?
if it is a nrv being fitted wrong way this would be behind units if fitted so would have to remove them.
this is for a new landlord who has had me given to them by recomendation so i dont want to have to charge them a lot if i can help it, but there again no other plumber fancies taking the kitchen apart to rectify the problem.
I think you've got a license to charge what u like on this job.
The landlord knows its nitemare and knows it's most likely gona cost him big.
Try the quick fix as I suggested but as above it could something more sinister like a back to front nrv or seized gate valve or who knows it could be a keen DIY'er that's done something completely unthinkable to us tradesman.
My advice - take as long as it takes and charge as much as it costs.
time is money as they say bud
well if water at first,then down to nothing,we have a blockage,air lock or ,if not working since new kitchen,maybe ball a fix valve not opened correctly
other plumbers would have checked for air lock,but connect hot and cold washing machine valves together and try to back fill
If no good,tap ok as same problem at washing machine valve
Try to trace pipe work and were valves from first fix or when alterations to kitchen would have been,does landlord know were old sink was,maybe isolation valve behind sink unit backing,if no luck,find out were hot supply comes into kitchen,maybe you could just re run from there under units,just removing plinth to sink
Would not give quote,case of how long is a piece of string and why should you risk loosing out because of someone else's mess up
Tell landlord your plan of attack,what initial charges maybe and keep him informed of further actions required and developments
imho
I had something very similar last week i think. when the tap was first turned on i got pressure then seconds later almost nothing, literaly a drip.
It was the hot feed to the kitchen tap. it was in 10mm plastic microbore underthe floor then up to 15mm when in the unit. i tried heaps of things cos i was certain it was an airlock. but in the end it was the 15mm elbow under the floor with the 10mm recducer in it that for some reason wasnt lettling much water through.
Also have you tried replcacing the tap cylinder?
i can virtually rule out the tap as the washing machine valve underneath is the same.
i have quoted a full days labour for 2 people and for electrician to come and remove oven and refit (probably wont need this so will be making on that but its been added just incase, and its been accepted so im happy with that. the bathroom is on other side of the wall and pressure is fine in there... so worst case scenario is to remove the units run new hot and replace everything - it wont take me longer than a day.
two things 1st has wm got hot and cold supply or cold only if both confirm hot is flowing to wm [may have to remove wm]
2nd if you can confirm hot supply to wm should also have supply to tap suggest obstruction in copper tail or flexi fitted to tap had this problem on two occasions it turned out to be solder in tap tails where system not flushed out properly good luck regards turnpin:)
remove the tap and test the pipework
trace the pipe work, find any valves, remove and test.
worst case scenario someone has squashed a pipe.
sometimes its worth just throwing new pipework in
tried that on the visit matey...
cheers though
thats what i'll do to be honest once ive got the oven out and the unit in the corner i will have pretty good access so will renew some pipework - the sink coming out to get that unit out is last resort.
turns out it was ruuning off an old pressure equalising valve, removed and everything ok.
apart from mixer valves on showers and taps what would of been the point of this??
electric shower, and modern mixer tap and seperate taps were fitted - so dont see the point of it....
Reply to thoughts please no hot water in kitchen in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a hot water cylinder which feeds 3 outlets (kitchen sink, basin in bathroom & bathtap) which has never had very good pressure (probably...
  • Locked
Just looking for some advice, I have just fitted a new kitchen sink and both water pressures are the same in hot and cold on the mixer tap, both...
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
F
Hi, My bathroom is getting redone in a few weeks. I have the option of 2 taps again or a mixer. I've seen online that if the hot flow is 'too...
