Discuss Thorn Heating Olympus 38/50B heating only to 18 degrees and cutting out in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
ronrocket
The above boiler has been excellent for 25 years. Recently, the temperature in house started to decline. The recirculation pump has been changed, and a new Honeywell thermstat fitted. Boiler fires up when the room is below 16 degrees, but cuts out when 18 reached It keeps coming on throughout the day, but never exceed 18 degrees (The same thing happened with the old thermostat)The New Room thermostat is set to 25 degreesAdditional Information: I closed down the boiler and then went through the To light the boiler procedure The Pilot light lit immediately However, according to the instructions, you then turn the boiler thermostat to 5, and the main burner will start. The Main burner did not startAnyone any ideas please
at 25 years old its time to start thinking about investing in a replacement. Apart fm that we cant comment on repairs on this part of the site
It must be starting sometime or the house wouldn't be heating at all. Get a plumber in. What you spend will save a few sleepless nights cuddling a hot water bottle.
Agreed
You need a gsr in to look at your boiler. We cannot and will not give advice on the installation or repair of boilers for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a pm to either Gas man or Redsaw who will then check you and then give you access to the gsr private forum.
Thank you.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to Thorn Heating Olympus 38/50B heating only to 18 degrees and cutting out in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hoping somebody can help, So, in a nutshell… Standard 90s Westbury home – condensing boiler, pump, wall thermostat, etc etc... Normal, common or...
Hi all, I'm really stuck with an issue I have with our soliud fuel back boiler system and my novice understanding is pretty much out of ideas so...
6K
Not an expert at all here, so please bear with me. We bought a Victorian terraced house early 2 years ago that was maintained quite well, with a...
1K
Hi! I have a 9 year old Baxi combi boiler. When I turn the central heating on, the boiler pressure is getting so high that it keeps cutting out...
1K
I have a Glow.Worm 30HXI boiler running on LPG. It has been excellent and no apparent problems or fault codes. Currently not running heating; just...
6K
