Discuss This discharge setup?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scott_D
Subscribed
Saw this on Facebook
Neat job but what do you think about the combined discharge pipes?
Not to regs as each cylinder requires its own separate tundish you can combine d2 aslong as it can take the loading
Also if they have combined the hot outs it's wrong
I have combined hots before on two cylinder jobs. Just always had a tee central so you get equal draw off
Exactly with there set up only the right one will be used mostly causing a legionnaires risk on the left also cold mains arnt equal
Reply to This discharge setup?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
