Discuss Thermostatic Mixing Valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys,
quick question regarding tmv's, I have been asked to install a tmv for a school as the childrens sinks are very hot.
They have 5 sinks in a row, would I need a separate valve for each sink or could I use 1 for all of them?
They do tell you on the literature how many litres per minute they can produce, so assuming all 5 may be turned on at once you may end up putting 5 in.
If they're low water using taps you can easily use 3 taps on one TMV.
If they aren't low use, then they should be, especially as it's a school.
This might help! Was given this by TRITON. Shows the flow rates against KW's and temperature.
Worth tucking away perhaps?
I would be looking at the minimum flow rates of the TMV's first.
We have encountered many problems with TMV's and one of the biggest is the flow rate through water saving taps not being enough to operate the TMV properly.
You may need one on each tap - particularly if its a school and also to cover your backside.
Reply to Thermostatic Mixing Valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have had an ongoing issue with low hot water temperatures in a school. During the recent repair of a leak, the plumbers isolated the hot...
Hi all. My hot water feed for my shower is on the left and the cold is on the right. My understanding is that this is correct and this is also...
I have NuHeat UFH system, and this has no Thermostatic Blending valve on the heating circuit. (Heat Master II cylinder has pick up coil) Nu-Heat...
Are there fundamental differences in some of these TMVs?. The attached one, below, would seem to be the better type where a shuttle moves to...
Hi all. My hot supply for my shower is on the left and my cold feed is on the right. My understanding is that this is correct and this is also...
Saneal
