Discuss Thermostatic angled valve question? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Jessiethecat
Hi all,
I've purchased some Valves online and they've come with a brass washer I'm just wondering which side the washers go in. The washer does come apart and one side is larger than the other.
ive attached a picture if that's any help.
thanks Jessie
8 or 10mm reducers?
The largest part fits in pipe to the valve, if required, not on the radiator side.
Hi Jessie, those 'washers' are reducing sets and go in the bottom of the valve if your pipes are 10mm. If your pipes are 15mm you can discard them.
Reply to Thermostatic angled valve question? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
