- Messages
- 282
When changing taps that are connected by an end feed or Yorkshire tap connector I always look to see if the fibre washer is ok, unless the washers looks as new I put in new fibre washers, but the washers sold in merchants always look thin.
Last week I fitted some new basin taps and changed the fibre washers, I checked and double checked the tap connectors for leaks and everything was fine, but a few days later the customer had a leak from one of the tap connectors, the fibre washer looked fine when I went back.
Can anyone recommend a decent fibre washer or what do you do in this situation?
Thanks in advance.
Thanks in advance.
