G
gfkw47
Hi
Last year we had our hot water system, which was electric immersion heater only, altered to provide additional heat from solar panels. Results appear to be satisfactory.
BUT in making the change the installers had to replace the hot water 1.5mtr cylinder (which had spray foam insulation), to a similar szed one but with a Gledhill "L" blue insulation cover. Not sure if Gledhill is the tank or the insulation cover or both.
With the solar system we can now monitor what heat loss takes place overnight. The cylinder gets to max temperature of 65deg all the way up from the entry point of the coil at the bottom of the tank to the top of the tank. But by the next morning, the top of the tank has usually lost about 7degs and reads about 58. While the bottom has usually dropped by about 14 deg to around 51 deg.
I know this heat accumulation is free when heated by the solar panels, but it still seems very wasteful, and in the winter months it is using electricity which is certainly not free.
Does this amount of heat loss sound normal - it may be that the old tank was losing a similar amount but we had no way of knowing. If it isnt normal any ideas what to do about it - does the Gledhill cover need replacing with something better? Or more insulation over the top of the existing one (although there is no space behind it to do this). The new tank size is 1500 x 450mm.
Sorry its so involved - but thanks for amyone who can help.
