Discuss Taking apart Lead joint on 4" Cast Iron pipe. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
joni os
Vertical soil pipe in 4" CI. Connections below collar I would prefer not to disturb.
Any advice on dismantling lead joint at collar.
Easy enough you need a big blow lamp heat joint till lead starts to melt and Flickr it hot with an old screwdriver or similar easyest if thjere a length above to wiggle it loose Beware the yarn will come out flaming
We did this on a cast stack last week blow lamp on full pap and lump hammer then smash but we was swapping it for plastic
Reply to Taking apart Lead joint on 4" Cast Iron pipe. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
