Discuss Swapping vales over live in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I’ve just swapped these new valves over live. Didn’t realise how bad the old nuts looked until finished the job. Would it be hard taking these valves back of plugging up the live water supply at the top of 90degree bend to remove the old olive and nut and fit the new nut olive then fit back onto the valves. Is there anything that I can plug into the top of the old 90degree bend for a few mins to do the swap over instead of my thumb as I did to fit below.
You wouldn’t be able to swap the nuts as how would you remove them eg can’t push the nut down far enough to get at the olives best to replace the push fit elbows
Ah I didn’t even notice that there wouldn’t be much space for the nut to drop to saw the olive. Could I replace the push fit elbows without draining the system down? Would I need to realise any pressure or can I just fit valve,nut,olive to new elbow and do a quick swap over under a towel?
I would drain the pressure and then just swap the push fit and valve over in one
From the questions you are asking I would advise you to get a plumber to do this for you.
It is not a big job and therefore shouldn’t cost much.
It can be done without draining the system, but you need to know what you’re doing and more importantly what to do if it starts to go wrong!!
It’s kinda why I’m here to ask for some advise, I wouldn’t imagine it isn't a very hard job as I’ve already changed over the valves in the attached photos without draining the system or dropping pressure then topped up the pressure on my boiler. I’ve been advised to drop the pressure so water obv doesn’t spray out with the pressure and would be a lot easier to change and was only wondering how to do it. Would I open the trv a little to release the pressure then by swapping both valves again there wouldn’t be as much pressure in the water? Also without dropping pressure I’m more than happy to change push fitting with the pressure of the water if it can be done? I’m not sure if it is possible as never done it before.
Reply to Swapping vales over live in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I have an issue with the standpipe trap in a 3-year-old flat. This flat came with a fitted dishwasher that has been completely unused for that...
… praying to the plumbing God, Bob Pictures and layout details attached, so be patient. 21 year old oil fired system in pretty good nick. I...
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the...
Hi, I have just noticed a damp patch around where my boiler flue exits through to outside wall along with a rusty colour around the collar of the...
I’m planning to drain down my system to replace the 3 way valve which has been buzzing away for months and occasionally sticking. While I’ve got...
3K
