R
richardlee
Hello guys.
I hope you could help me out here.
I am fitting a new bathroom and as part of it I am installing a new shower from a shower pump with dedicated feeds off a 50 gallon loft cistern for CW and an essex flange from the Cylinder for HW.
I will also be fitting a bath filler which is a twin lever type and a basin mixer which is a single lever type.
My feed to the bathroom at the moment is gravity HW in 22mm and mains CW in 15mm, the original bathroom had seperate hot and cold taps on bath and basin.
My question is this: Should I run a seperate gravity CW supply to the bath and basin mixer from the loft cistern? And if so, could I tee off the 22mm CW supply to the HW tank or the 22mm supply to the shower pump or must I fit another tank connector to the cistern (which will give me a total of 3 tank connectors!)? Or can I just use the mains supply for the cold? I dont think the bath filler is such an issue as it has individual controls for hot and cold but thought that the pressure difference between the hot and cold on the mixer may be an issue.
Thanks very much.
Richard.
Thanks very much.
Richard.
