Discuss Superser element won't light up in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
J
Jon Lewis
I have a 2 bar mini superser. It ignites OK but makes a rumbling noise when lit. Also the second element won't light up when button is depressed
Reply to Superser element won't light up in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello, I have a customer with a modern anthracite vertical radiator and a modern TRV and lockshield. The radiator makes a loud metallic bang from within the radiator, when it heats up and cools down. I have opened the lockshield fully, lowered the boiler pressure from 2.5 bar to just over 1...
Hi all not a plumber but am an engineer I have pressure drop in the system Worcester Bosch came back after repressureising the expansion vessel and he replaced the heat exchanger element. The boiler is coming up for 15 years old. The boiler was going below one bar and not increasing when...
I have just had a new boiler and 210 ltr unvented tank fitted in the loft to replace a very old Baxi back boiler. I have now fitted a Solic 200 diverter to utilise all the spare capacity from the 3,84 Kw Pv system on the roof. This has only just become an option as the old existing tank did not...
I had a new Grandfos UPS3 pump fitted today, and am trying to set it up. I want it on 2nd setting, but having problems. The green light is on setting 1 and there is a yellow light on setting 2. If I press the arrow the green light stays on 1 and I then have yellow lights on settings 2 and 3. If...
I am having a problem with my main 24he boiler where the flame is constantly clicking on and off with the heating and when using hot water. Some times the flame failure light comes on but it ignites again after a few seconds. The plumber has changed a couple of sensors on the boiler and checked...
