Discuss Struggling with back flush on a close-coupled toilet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all,
I've been asked to fix a bit of a bodge - a close-coupled toilet leaning slightly to the right is leaking from the right hand wing nut after flushing. I've replaced the donut and fixing plate, smothering it with silicone in the end so no water could theoretically get out (this was a last resort and isn't how I generally do this job) but it's still leaking when flushed. The syphon is fixed in nicely so no water can get out but the pressure of the water when flushed is causing a fair old leak. In 10 years of toilet repairs I've never had this so any helpful hints would be gratefully received. Cheers all.
Do you know who manufactured the toilet?
Armitage had a toilet that was a nightmare to seal.
Sometimes you have to make washers yourself. Cutting a standard foam flat washer (not domed) in half, so to reduce it's thickness & putting it on top of the donut washer can often seal it.
I've had a couple of these nightmare fellows. It's probably complete co--incidence but in both instances it was an ideal standard (flat c/c plate, floppy rubber douhgnut washers)
In the first instance I finally got it to seal after two visits and 20 attempts by using a sort of trench of plumbers mate and swapping the drop valve I was trying to install for a handle syphon to lessen the oomph. In the second instance I gave up and told her to try someone else with a fresh pair of eyes. Nothing I tried worked.
95% are fine. But the odd toilet will ruin your day.
Next time - if it's white - I might just "accidentally" hit it with a hammer. New loo.
Just tell the client don't worry it's just a bit of condensation.....
Use the denso tape in conjunction with donut, as a lot of the cheap donuts compresses to nothing and can not create the seal, denso will. Have done this quite a few times now over the years when nessesery with no come backs. Hope this helps.........
Reply to Struggling with back flush on a close-coupled toilet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
