Discuss stopcock found after 30 years! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My mum has just had a new boiler fitted and we found the stopcock sticking out the plaster behind the old boiler. I have been looking for it for ages so it was quite nice to finally find it. Do you think it is safe to try and turn it after putting some wd40 on it and leaving it for a while?
Picutre
If it was in my house I'd try it but only if I had a free afternoon and there was a local merchant open or I already had all the parts I might need.
In a customers house I wouldn't touch it unless I was there specifically to fix it.
The only reason I'd touch it in my house is I know how to fix it if it leaks/breaks/falls off/explodes/opens a wormhole to hell and looking at that pic I'd say at least one of those things is likely.
Our outdoor one was down a hole and didn't shut the water off significantly, got the water board to fit a meter for free which comes with a shut off. No idea how they fitted it without getting soaked though.
In your case op i would just replace that one and replumb it outside of the wall too for that matter! No point leaving something like that in place as you wouldn't use it anyway.
In my road all company stopcocks, unless metered, are in the front gardens and not easy to find.
One house badly flooded when owner away and keyholder had problems finding cock in house.
Perhaps a notice just inside front door as to where to find cock would be helpful.
^^Yes yes...there is an all female plumbing firm called "stopcocks" why not give them a call to see if they like handling a stuck cock.
http://stopcocks.uk/
I couldn’t care less and good luck to them but I can’t help feeling if a bloke set up a company called noflangeplumbers or something there’d be uproar
got the water board to fit a meter for free which comes with a shut off. No idea how they fitted it without getting soaked though..[/QUOTE said:
They didn't!
I had them out to change a broken stopcock and they dug the hole, cut the main live with a petrol saw and then fitted the new stopcock. And yes, the fella got soaked.
It was quite funny because we were working on a ground floor maisonette and shutting of the stopcock turned the upstairs off as well. We warned the (big and burly) bloke upstairs who was ok ish about it as long as we were quick because , and I quote, " I've got me bird coming round soon and I need a shower and a s**t before she gets here"
So when the stopcock wouldn't turn back on he wasn't very happy. I sent the lad up to tell him.
Water board were out in a couple of hours though.
Reply to stopcock found after 30 years! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
