Discuss Sterling 40 st 109 boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
richardd
Can you pressurise the sterling 40st 109 boiler . I need to install an extra rad in the loft area for a friend so i need to pressurise the heating system. Can this be carried out with the boiler mentioned.
Thanks in advance
depends if it has a high limit stat,if not no way you will create a bomb
how do you if it has stat thanks in advance. Can one be fitted
check with the manufacture or mi,s some do sell high limit stat upgrade kits,in regard to be able to tell in advance that would be a long reply basically its down to experience
Searching the web for a while now cant find any info on the manufacturer or contact numbers
try gas safe,they will know or can point you in the right direction
Reply to Sterling 40 st 109 boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
