Discuss SP140B vent pipe adaptor fitting in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, ive recently purchased a Sp140b adaptor for cement pipe to 110mm plastic. When I've looked the vanes end is fine to put into cement pipe but where it has described the other end as push fit I was expecting to see some kind of o ring or seal for 110mm plastic pipe to slot into. Would I be right in returning the item as faulty?
Yes there should be a rubber seal about 10mm from the end is this not there ?
Reply to SP140B vent pipe adaptor fitting in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
