Discuss Source-Drain cock replacement washers..? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pssst
Does anyone do packs of these...? Sick of changing drain cocks..!
You can get them from Toolstation or Plumb center in packs of 5
Reply to Source-Drain cock replacement washers..? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My father is getting quotes to have his back-boiler replaced. The firm he wants to use have told him that they will have to fit drain-offs to...
Hello, I'm installing my first Belfast/butler kitchen sink. It came with the waste and stainless steel drain. To my surprise the kit only has one...
Hi all, I'm trying to source a replacement pump for my heating system, I suspect the current pump is an older version that has been superseded...
Hi, I’m looking to find a replacement Collector circuit pump for a ground source heat pump. This is the pump on the brine circuit. The pump I...
I want to replace a radiator that has a drain valve. Do I need to replace like for like and keep the drain valve in or can I replace with a...
