T
TallulahGosh
In need of a bit of advice if possible?
Recently moved house and just trying to get to grips with the heating system before it gets cold enough to actually need it!
All rads bar one have a TRV. A couple seem to be stuck in the MAX position but I'm hoping a bit of WD40 will sort that tomorrow. My main problem is that the one radiator without a TRV is in the hall, directly next to the front door. As there isn't a wall stat anywhere in the house, the hallway rad is scalding as soon as the heating goes on and then stays that way. The hall gets ridiculously hot and with the rad's position it's only a matter of time before myself or my daughter burn ourselves on it - clumsiness runs in the family! I have noticed that the rad is in a tight spot, only just fitting between a wall and the front room doorway and has no covers on the valves at either end - I have no idea if this has any significance but as it's the only one like that in the house, thought it was worth a mention.
Is there an obvious reason to the trained eye why the heating would have been set up this way?
Also, what is the simplest, most practical solution that will enable me to control the heat in the hallway?
I'm not the most competent when it comes to plumbing related DIY...although I can fix a leaking urinal at 4am any day of the week...so chances are I will get a local guy to come and do any work for me. I'd just like to know what I'm talking about before I get to that bit - makes me feel less of a bimbo! :bucktooth:
