Discuss Soldering issues in the Plumbing Jobs | The Job-board area at PlumbersForums.net
direct-network
Wondered if someone can help me,
I am using rothenberger mapp gas with a bullfinch torch. What i am finding is when im trying to solder 15mm copper fittings, they are burning (going green and green flame) before the solder is taking to it!!
Any tips (im also using powerflow flux)
Don't use so much heat. If you can't get away with mapp try propane.
It's more or less on the lowest setting, it's not roaring and you can barely hear it!!!! tut just bought a new canister, will pick up propane too then
Mapp is too hot, use the black bottle gas. Rothenberger gas is a total rip, get a primus/sievert adapter for your gun and you'll save a fortune.
Sent from my iPad using Tapatalk HD
Hi thanks for your message, i've only just started soldering really, what is the primus/sievert adaport for?
not always the case, disposible gas bottles are roughly the same price as primus refills, but you get more gas in a disposable
DIY / Professional Range | GoSystem
get the above torch, i have soldered 35mm copper pipe with it but its perfect for 15mm pipe as it has a small flame when set low. Power torches are great but not really needed for general plumbing especially for somebody new to soldering, you can use it on porpane and mapp gas bottles..
I have seen them on slae in b and q for around £16-£20 pounds.
you have to use a lighter/sparker to light them but whats a disposable lighter cost.
bloody hell i was looking at them but thought they would be sh** so went for a bullfinch. not easy finding the right setup is it?
Also i'm struggling with the gas and torch and wondered if you can get the bottle seperate and have a hose?
better to keep the bullfinch torch head and just change to propane
you will find propane alot easier to work with.
Dunno where you're getting your refills, but they're less than £4 at my merchants, rothenbergers are £8 minimum according to net so essentially twice as much.
Rothenberger have a new torch on offer at Graham's which has separate bottle and torch on a hose.
i've got both a primus 2000 and a superfire 2
just bought a refill for the primus a few weeks ago £7.60
i can get disposable propane for under £7, not rothenburger but similar.
the disposable bottles are 400g but the primus is only 360g
i never seen primus gas refills for £4 for a long time, where you getting them at that price.
only makes it more awkward to carry around though, and hose ends up getting damaged etc
better not to go down that road imo
you also have to include the inital cost of the 2 primus bottles or the cost of the petrol and time lost going down the merchant to get more gas.
primus have less of a carbon footprint tho.
I always found the primus dirtier than Rothenberger. Used to get a soot deposit on the fittings.
Plumb centre mate. £3.85ish plus vat. I have 2 bottles in van at all times to use with y superfire 2.
Primus 2000 was the torch to get for years up here. If you had anything else it was usually hard to get refills. My usually torch though was a 7kg bottle of propane, tube and torch, saves waiting for refills so often.
But they will not allow the 7kg bottles in multi story blocks in case they leak and the gas goes down the service ducts.
I have also used Petrol and Paraffin lamps. When you have used those you realise how easy gas lamps are to use.
A mate of mine put a petrol lamp on a cooker gas ring in a customers house to warm up and then forgot about it. Result new back of house.
Both where great when cold they where like flame throwers and a well pumped cold lamp flame could reach 15 feet no bother with its flame. Surprising what amuses you when your young isn't it?
move the flame about the pipe and fitting more, if you keep it in one place, it tends to burn the flux out. Move the flame away from the fitting and touch the end of the solder where the pipe meets the fitting frequently to see if it is hot enough to melt the solder.
Make sure you've got the tip of the miner blue flame on the fitting when soldering.
Soldering is something you do subconsciously ie you do it without thinking. It is something that is actually quite hard to explain how it is done properly. Any boys i have had i would tell them to watch the flame, don't burn the flux etc etc and they would get leaks if i wasn't watching them because they were concentrating too much trying to follow what i said. I learned to just let them find their own way.
It is just an instinctive thing you will learn.
Btw bin your mapp gas. It is too hot for normal work. It is twice the price, it will discolour your pipe and burn out your heat mats. It solders quicker but takes longer to cool.
Some like it because it is hotter but the only real use on a domestic is if there is a touch of water in the pipe. You can solder with oxy acetylene or oxy/propane both of which are even hotter but why would you.
Lighting it on the kitchen floor with the flame squirting up the wall and no one batted an eye. How times change lol
I had this happen this week when working outside. Flux had got damp. Throw out and buy fresh. I have a 500g tin of flux in the workshop and little flat tins in the toolbox. I fill the little tins up from the big tin save the whole lot spoiling.
Reply to Soldering issues in the Plumbing Jobs | The Job-board area at PlumbersForums.net
