M
Mikerobson
Can someone tell me why I'm making such hard work of making a simple soldered joint?
I am using FRY Power Flow lead free solder and FRY Power Flow flux.
I clean the pipe end with emery till bright and cover with flux, I do the same with the inside of the fitting.
Put the two together and heat with blowlamp, remove blowlamp, touch with solder which just goes into a ball and rolls down the outside of the fitting.
I managed to do one successfully and the solder was absorbed evenly into the joint but I have no idea what I did different!
Any help would be very much appreciated!!
