Discuss Solder fittings advice pls in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
When using solder ring fittings is it important to have one end of the pipe open to allow pressure and fumes to escape?
I had a terrible job trying to solder a short section of pipe with an isolation valve closed on each end. It wasn't till I redid the work and opened one end that I could get it to solder successfully.
Was there water in the pipe ?
100% yes as water would of gone to steam and pressurised the pipe need to keep an open end where there’s any water to steam / boil off
Reply to Solder fittings advice pls in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
Hoping somebody can help, So, in a nutshell… Standard 90s Westbury home – condensing boiler, pump, wall thermostat, etc etc... Normal, common or...
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing...
HI everyone, I'm looking for some thought/opinions on what could be causing issues with noise and pressure since having a pressurised un-vented...
