U pipes are very efficient but they have had problems with the braze fracturing where the pipe enters the manifold I'll stick with heatpipes for now.
That was the case for the newer less experienced companies in the past. The key is finding a product produced by a factory with knowledge, experience and professionalism. Not all U pipe manufacturers had issues with the braze fracturing. The same could be said for when Schott had issues with tubes blowing; no-one else had those issues, but many companies caught a cold as a result. The problem is, as soon as a product is seen to be successful it spawns a plethora of 'me too' type companies wanting to jump on the bandwagon and copying the successful product. Unfortunately most do not have the expertise and/or the technical knowledge to produce to the same quality, although some can take the technology and improve on it, As with all things it pays to dig a little deeper. Quality of copper, glass manufacture, process and nature of the absorber layer are all just as important to the performance.
The pure tubes are produced in the same factory as Kloben tubes, with over 50,000 collectors installed in over 16 countries globally with 10 pcs that have failed in total. Commercial installations of 350 - 2000 sq. m installed without any issues.(of the 10 failures, 6 were down to installer error.)
Heat pipes are out-dated, you’re not offering your customers the best ROI if your offering them heat pipes only. We supply both types of evac tube collector and flat plate, U pipe is by far the most popular by those in the know..
We have confidence in what we are supplying and so do our trade customers. Feel free to get in touch when you next have an installation, I guarantee you wont use a heat pipe again once you have installed the pUre series!
