Discuss Solar divert & SysteMate 2000 in the DIY Plumbing Forum area at PlumbersForums.net
I have moved into a property with a Gledhill SysteMate 2000 and not much clue as to how it operates!
I am also considering installing solar panels at my property and investigating if I can use the generated electricity to heat the water in the thermal store. I have found the myenergi Eddi device and am wondering if this can be installed alongside the SysteMate 2000 to heat the water using the heating element in the tank?
Probably is the answer.
Ask the solar installation companies you get to quote to include this.
BTW heating your hot water from your excess solar is a PERFECT way to increase your return on investment.
Reply to Solar divert & SysteMate 2000 in the DIY Plumbing Forum area at PlumbersForums.net
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
