Discuss Small leak at bottom of radiator (see photo) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi!
My girlfriend has just sent me the attached photo .There is a small dripping leak from the small stubby sticking out bit below a radiator. Enough for the pressure to drop a it (boiler repressurised). She said the end was hand loose so tightened it. The radiator is not a slimline type and has no bleeding valves etc. at the top as far as I can see. What is this small stubby pipe ...and why should it suddenly develop a leak? (the wiring below is for old cctv and not live!)...THANKS.
ok thanks ....she has tightened it a bit....is the washer in there rubber or metal?...and if it needs replacing is a drain down (or freezing the pipes either side) the only 2 options?...thanks
Yep a little rubber washer , there is a way it maybe able to be done live , but unless you know how to do it that way , you will be safer draining down .
probably wouldn't have to do a complete drain down, as it is pressurised you should only need to knock the pressure off.
Reply to Small leak at bottom of radiator (see photo) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
