Discuss Slow/low flow rate to radiators ...I think in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
Nelly Mac
Hi, think we have a flow problem in our central heating....but don't know how to tackle it..
We've an old CH system, which was installed before we moved in 16 years ago...and to be honest not well serviced, but has never let us down. BAXI boiler and expansion tank in loft, that feed a pump and HW tank in an airing cupboard below. The boiler, or surrounding pipes, have been a bit clonking when it first fires up, and on one occasion I saw steam or air spluttering up out of higher expansion tank. But we have plenty of hot water in the tank and pipes.
We extended the house around 12 years ago and now have 11 radiators.
The main issue at preset is that more and more across this winter season, many of the rads would not get hot. I did all I could to balance them. But unless i closed all but the further ones...I could not get heat to them at all. Back up stairs the pump would be whirring away...and the pipes either side of it red hot, and likewise both the A & B feeds after the 3-port valve.
I wasn't convinced the old analogue room thermostat was effectively clicking on/off...so replaced that with a Honeywell digital one. Didnt make much difference, but at least I have accurate readings now
The Groundfos 15-50 pump was a bit rumbly at times, and only smoothed out when I turned it up to speed 3 (it had previously always lived on 2). Then only 3 would work at all, and I could just hear and feel it purring, but turned back to 2 or 1 ...and nothing. So i assumed the old pump was on its last legs and couldn't cope pushing all over the house.
I installed a brand new UPS2 15-50/60, which purrs on all speeds - and has an 'intelligent' setting too.
But cranking up the new thermo to really high - and with the pump on its top speed...slowly, slowly, painfully slowly ...over an hour or two heat gets to the rads. We can never get above 21'c
Some red hot - some still only tepid...so I continue to try and balance, but notching up and down the lock-shield valves (we have no TRVs) ....but so easily can one quarter turn seemingly send another once hot rad, cold....and the wait for a warm house is sooo slow.
I wondered about the 3-port valve. But the A & B pipes either side are red hot, and when powered off the little auto lever does offer motor resistance and spring back....which I was told was the first obvious check that its working ok.
Is it all fighting against some sort of blockage somewhere ? ....when I've taken rads off for decorating, we get dirty water of course....but not sludge or filth you would associate with enough build up to block, and clear water when bled from the top...but the systems not been flushed.
So, what can you suggest.... I may have an old boiler (and cant really afford to replace that at present)...but stacks of hot water in the boiler and 3-port pipes...and a brand new UPS motor next to it whirring away (which I'm worried is overworking to the extent that killed the last one).....which takes an hour or so to just (just) get 20'c+ heat to the thermostat in the hall, and leaving radiators very varied around the house, despite efforts to balance them. Just seems to lack a decent flow rate.
....any ideas please
thanks
System full of crap. Partially drain down, stick some cleaner in loft tank, run for a week, drain out and refill. Dont forget inhibitor.
To do a more thorough job, after you drain down to empty the system cleaner, take all the radiators off one at a time and rinse out thoroughly with water from a garden hose.
Reply to Slow/low flow rate to radiators ...I think in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
