Discuss Slightly moving waste pipe connection into soil pipe in the USA area at PlumbersForums.net
Parents have had a steel beam put into their hallway ceiling to adequately support landing and stairs.
This means that the waste from a sink and shower will need to be reinstated slightly lower into the soil pipe, as the pipes will now run under rather than through the beams (the joists will be cross battened for slightly lowered ceiling).
The current waste connection into the soil pipe is a massive old bodge so it needed redoing anyway, but the proximity to the old hole in that pipe is likely to be problematic... I’ll try to attach pictures.
Any thoughts and advice please?
The solution is going to be to cut out that section of soil pipe from the connector above just under the floor, insert a short new piece and start from there.
There may be enough room to get a short boss section in to save cutting the hole and fitting a strapon boss.
Thanks... assuming that the boss has a stop in it, IE not a slip coupling, I’m not sure how I’ll be able to get it in to the stack...
I don’t have any leeway for moving the pipe above upwards.
Just wondering if it would be feasible to cut a collar from another piece of soil pipe with one side slotted so that it can be sprung around the pipe, and solvent welded in place?
I think there's enough room to cut stack at top of hole, remove and clean up remnants of existing boss and fit a proper 110mm boss fitting with additional slip socket if required to get it in.
My preference would be to cut in loft and run a full new length of 110.
Hi
It would best to install thread tee connector reducer bushing
Unfortunately there’s a toilet connects into the stack just above that joint - it’s all boxed in so impossible to change or move the pipework above where I’ve pictured.
You'll need to remove the boxing in order to gain access and then replace it again after. IMO, this sort of job needs to be properly without cutting corners and then proved with a pressure/smoke test before boxing it back in again. This is not 'impossible' for an amateur to do but it's more than most DIYer's would want to take on as a project.
I'm a bit worried that you are relying on 'an elbow stuffed with rag keeping the smells and water in the soil pipe'. Sewer gas is always a health hazard and can be very dangerous; you need to get the system properly sealed and airtight.
Sorry, whereabouts do you mean?
That image may be misleading as there’s just a piece of pipe and an elbow stuffed with rag keeping the smells and water in the soil pipe, the original pipe from the sink and shower were all removed as they went through excessively large holes in the floor joists.
Hi
sorry to mislead I've not seen the original pipe from the shower and sink
Struggling to find a place selling a 63mm to 40mm solvent weld boss adaptor, other than the ones online.
All of the usual physical outlets seem to favour the rubber bung style adaptors... I’m not too keen on the idea, seems a bit daft if I’m going to solvent weld all of the pipe up to the soil stack boss, to then have it connected in via a rubber bung...
Plumb centre City plumbing / your local plumbing merchant have them
Lower part of branch before cleaning
Short socketed section onto bottom of branch
Stub added into floor socket for slip coupler to overlap
Boss pipe solvent welded
40mm adaptor for pipe from shower and basin
Slip coupling over butt joint. This was difficult, despite lots of lube!
Looks good yep slip couplings arnt the easiest to move / set
I actually used a standard above-ground Floplast double socket coupler, and Dremel sanded off the two small stops inside. The main issue was that the collar that keeps the rubber seal in place kept popping off when I pushed it over the end of the pipe. Once in position however I was able to click it back into place.
By contrast, the Floplast below-ground double coupling is advertised as having “removable centre stop to use as slip coupling”.
Perhaps there is an equivalent above-ground type but I wasn’t able to locate one…
If its your own family and you know no ones got hep, cholera, covid, typhoid etc you should be fairly safe - make sure you wash your hands before your tea!
Municipal / communal systems on the other hand ⚰️⚰️ !
Would agree hepatitis is very nasty you can now be inoculated against all types.
I had it done few years ago when we did large upgrade/replacement of cast stacks and drainage job.
All completed a few weeks back - rather a lot of joins on the shower waste but it’s much smoother and more direct that the old setup which doubled back on itself rather unnecessarily with horizontal runs and little fall!
Looks spot on to me 👍
Reply to Slightly moving waste pipe connection into soil pipe in the USA area at PlumbersForums.net
Obviously I know the boss parts on a soil pipe tee are there to be cut out to connect waste pipes and I have done this when it is not a horizontal...
3K
A
Hey, I'll start by saying I'll be getting a plumber out to do this but wanted some advice first. We're redoing our ground floor bathroom this year...
I am moving the position of a WC which connects to the roof vent pipe and discharge pipe. To do so I would like to rotate the soil pipe about 40...
2K
TL/DR: Can I have a bend of 90 degrees in the dry section of a 4-inch soil vent? Hi. I am renovating a small bathroom. There is an awkward part...
2K
Hi I need to connect a kitchen sink to a soil stack but the soil stack has an inspection hatch and what looks like a reducer into a clay pipe...
3K
