Discuss Sime Super 60 / Potterton Profile 60e in disguise in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Spreck
Hi Guys,
I've had a call today to one of these and had been pre warned of an intermittent ignition fault didn't happen while I was there!!
FGA came back good on PPM & Ratio, flue looked good no signs of degradation so ruled out visiation
Gave the exchanger a good clean & the burner ports clear flame picture fine.
Cuts in and out fine with the temperature dial, ignition probe clean...
Pump running , water present...
it it would seem that after running fine once desired temperature reached it takes about 3/4 attempts to re-ignite?
but not every time? & not when I'm there!?!?..
any help or time served would be good as I'm expecting a call back if it crops up again.
is it lighting fine just taking a few attempts? not locking out?
Nope not locking out just a bit slow on the uptake from what the owners have told me, oh forgot to say tested the integrity of the case seal with smoke stick all good.
well if there's no issues with the probe,leads,or pcb and its otherwise working fine leave well alone ,electronic baxi bermudas can be temperamental in there lighting sequence does not always mean there's a fault ,clicking 4 times randomly before igniting is one i would leave well alone
Reply to Sime Super 60 / Potterton Profile 60e in disguise in the Plumbing Jobs | The Job-board area at PlumbersForums.net
