Currently reading:
Showerlux bifold door installation/disassembly instructions
Discuss Showerlux bifold door installation/disassembly instructions in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Our shower has developed a leak. It is a tiled cubicle with a porcelain shower tray and an old (at least 20yrs) Showerlux bifold door on it. It is leaking from somewhere near the door frame on the far side from the shower head. I can't get it to leak by just running the shower by itself or by standing in it and pouring water over the seals so I'm not sure whether the leak is down to perished sealant or because of an issue with the door. I will replace the sealant as this is probably the most likely culprit.
But while the shower is out of action I wanted to take out the door and give everything a good clean/descale and check there were no issues with the fixings.
My problem is I can't dismantle it and can't find any instructions for assembly or disassembly on line (as Showerlux went out of business some time ago). Does anyone know how to remove the door from the frame? My guess is that one of the panels might lever off, but it has been pretty resistant to me careful attempts to get at it (I would prefer not to break it).
Anyone have any ideas how to remove this intact?
TIA
Ian
1. Don't know for sure but you might need to uncouple the base of the door from its guide rail, then lift the door up and out.
2. I'd be tempted to try and solve the leak first, then see if its worth cleaning the door and frame.
3. There may well be seals / plastic parts inside which have hardened with age, and will break when you try and remove them.
Reply to Showerlux bifold door installation/disassembly instructions in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
