Discuss Shower waste trap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
pjb_1972
I have a shower cabin and the waste trap has cracked and some bits have broken off hence it has started leaking. I tried to find a replacement but it seems to be a non standard size. The hole in the shower tray is 80mm - where the hell can you buy a replacement trap from of that size? Its driving me crazy! I've tried patching up the existing one but its a bit of a mess so I really need a replacement. I can't just replace the tray either as its part of the cabin.
Grrrrrr! Any help much appreciated!!
Hi there 50mm 70mm and 90mm diameter wastes are readily available not too sure about 80mm try re measure and see if a 70mm will fit plumbfix/screwfix sell these..brum
Reply to Shower waste trap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built downstairs shower room. Recently he had this downstairs shower room re-fitted/decorated. Quite a simple set up consisting of a sink, toilet and shower...
I have bought a shower tray and it has an extra large hole for the waste trap. Its a cooke and lewis think its an eclips 1400 x 900 tray. The hole is 160mm and has a lip around it for the cap at 200mm. Cant seem to find one in the correct size, hope someone can help.
Hi, I'm trying replace a basin waste and I cannot get the chrome ring attaching it to the trap undone. It's not a nut so using a wrench with rag is just slipping. I've tried release spray but still no movement. Any suggestions? Cheers, Andy
I've got an issue with the shower tray not being totally flat. As you can see from the photos, it is about 7mm out at one side. It's leaning towards the waste end though. The shower tray is pushed underneath the tiles. My mate did the tiling and I now realise that we should have put the shower...
Hi, I am trying to clean out my Merlyn Truestone slate shower tray waste unit. I cannot see anyway to remove it to clean underneath. I'm stuck trying to fish out debris which isn't working great. Could anyone please advise if I can remove this or a better way to clean the debris? Thanks
