Discuss Shower waste hole not quite big enough for 90mm shower trap in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I attended a customers house to fix a reported leak from their shower waste. Turns out there was a split in the trap. Straight forward I thought and got a standard 90mm trap from the van. Turns out the hole in the shower base isn't big enough to fit the top section by the width of the thread on the upper section. When I measured the hole it was only 85-86mm wide. Has anyone else come across this before? The waste that was on there was unbranded and I haven't been able to find an equivalent online. I'll expand the hole if necessary but I thought all shower tray waste holes were standardised.
Is the hole recessed Does the new trap fit in it eg the indent ?
Could be imperial depending on age
Did you fix this as I'm having the same problem.
I ended up cutting all the silicone off the existing trap and carrying out a repair with mesh reinforcement and superglue. Took an age and I was worried it would leak after a bit but it seems to be holding up ok a year in. The only online supplier I found couldn't tell me when the waste they had that should fit, would be back in stock.
Reply to Shower waste hole not quite big enough for 90mm shower trap in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I managed to get the broken shower waste body out of the trap. I'm about to fit a new waste, a much more robust brass item. The trap has a big...
2K
I am really struggling with how to do the waste pipework from a shower tray and would appreciate any advice on the best approach to take. The...
2K
Deleted member 120897
Hi, I've got a problem which I can't see a solution to, a future customer of mine wants to add a low level shower where a bath used to be, the...
2K
I’m currently considering how best to do the pipework from the shower trap (90mm, 1.5”) and I just wanted some input from you guys and which is...
