Discuss Shower valve siting issue in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi, I'm new to the site and am hoping someone can help with a bit of an unusual problem. I recently bought a house and need to replace the shower. The one that the boss wanted leaves a gap around the valve when fitted. It looks like the present one was a diy job because the holes for the feed pipes behind the valve shrouds (hope that's the right word) are way too big and are barely covered by the existing one. Another couple of mils and the shroud fittings would go right in, and they are quite large to start with. So the new valve had to be moved to one side slightly to enable me to make it secure with the fixing screws. This obviously leaves quite a gap to the other side of the smaller shrouds. The shower cubicle is more recent than the rest of the bathroom and has the multi-board type walls.
We are not without a shower as it is quite easy to rig something temporary up when needed, but I really need to sort it out.
Thanks for any and all help. Bob
Reply to Shower valve siting issue in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi everyone. I'm installing a walk in shower, opening into shower will be on right, mixer value on right, but shower head and drain on left. The...
1K
Hi, I need to remove some radiators for redecorating and went to try and shut off the valves either side of my rad. I have TRV on one side and on...
Need a bit of advice for installing a shower mixer valve. Issue Im having is that the tiler put the tiles on and the gap has went from 150mm to...
1K
J
I have an Arteform shower valve in my bathroom - top lever for the main shower head, middle for the handheld hose and bottom is the thermostatic...
I'll start this by saying I'm hoping to sort this by diy / minimal professional help as I'm a very tight budget! I've got a walk-in shower in a...
