Discuss Shower valve replacement help please in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi all,
Bit of a plumber novice that’s for sure, so apologies if my question is very basic or I haven’t made it too clear.
In essence, shower isn’t very warm, boiler and that is fine. Suggestion was thermostatic valve or mixer valve may need replacing. I have stripped the turners back along with the wall plate.
Looking at the bottom temp control it wasn’t quite as I thought, it appears to almost be one whole unit. Have attached a picture.
Hopefully someone can offer some advice around changing it for the correct replacement (wish I knew the make)
Thanks in advance.
Reply to Shower valve replacement help please in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi Guy's, Looking for some advice on an issue I have having with a recently installed thermostatic mixer shower in my ensuite. Everything was...
Hello. My mixer shower (non-electric) recently started running luke warm. I know this can happen at this time of year over winter but I've been in...
A
https://victoriaplum.com/browse/all-showers/type_Exposed-mixer-showers?csi=SHS30&ds_kid=92700067325954114&gclid=CjwKCAiA8OmdBhAgEiwAShr407d2c-jzpnz...
Angela Butler-Harvey
A
I have a thermostatic concealed shower and would like to remove the thermostatic valve and look to clean any debris as it doesn't appear to be...
Can anyone please advise which replacement shower mixer valve thermostat I need foe this shower control
