Discuss Shower thermostatic cover stuck fast! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I need to remove the thermo cartridge from our shower to de-scale - it has not been taken apart for 13 years. I have taken the hand-wheel off fine. The cover is a 'pull-twist' kept in place with an O ring and does not have a retaining screw, but it is stuck fast and won't budge. I have used (and snapped) a strap wrench, WD40, gone round the edging with a screwdriver to try and break the seal etc etc all to no avail. Help!! Have put a picture in attachment (I think).Any advice much appreciated
Try removing the trim from the front. Might be a circlip. This might then reveal screws to remove the insert.
Post a pic from the front.
Thanks - please see photo from front attached. LB have assured me that the cover is 'twist and pull' which means I have to get it loose. Any suggestions? Hitting (gently) with a wooden mallet??
Reply to Shower thermostatic cover stuck fast! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a Aqualisa Midas thermostatic shower that has a very stiff temperature control. I have taken off the control knob and unscrewed the...
2K
Help! The shower thermostatic valve has snapped with half of it stuck inside (the front and centre of the valve are out). Long nosed pliers and...
8K
Hi Guys, I have a leaking thermostatic cartridge and I'm trying to replace it but I cannot find the part number or any no-name ones with similar...
5K
Good morning everyone :) I’m having issues with my thermostatic mixer on my shower, I want to strip it down and clean it up inside but I can’t...
3K
Hi UK Plumbers Forum! This is my first post and just want to share a very simple “How-to” on changing the thermostatic cartridge on the Triton...
4K
