Discuss Shower temperature - too hot to handle! in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I have a Mira shower linked to my hot water tank which works well when my boiler thermostat is on the LOW setting. The water temperature is controlled using the rotary dial and I'm able to adjust it to make the shower warmer or cooler as required. Unfortunately when the boiler is set to HIGH (or when bypassing the boiler when it was recently faulty and using the electric immersion heating element) the water is almost at scalding temperature and is completely uncontrollable. Moving the rotary dial to a cooler temperature has absolutely no effect and the water remains at a very high temperature; the shower is effectively unusable as I am unable to reduce the water temperature. Any ideas - is it any easy fix or is it a plumber job? Grateful for any suggestions. Thank you.
Your description make me think the cold water feed to the shower is insufficient. This could be a strainer that has clogged, an isolation valve left partially closed, an inverted-U section of pipe containing an air lock, pipe that has been crushed/kinked, etc.
Many thanks for your reply; I'm now checking the various suggestions made. Much appreciated.
Probably got boiler running at lowest cycle. Be careful, legionella and waters to be stored @ 60 degrees.t te To be honest no ideas' ??
The immersion back up is probably set the right temperature, as for the blending its like the mixings taking place in the valve body and the hots the better pressure doesn't allow it to blend.
Is the unit a thermal storage??
Reply to Shower temperature - too hot to handle! in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi, we were getting uneven shower pressure and fluctuating temperature from the shower. A plumber advised that we replace the shower which we did...
Hi all. Sorry I'm not a plumber so go easy on me. I have a triton shower (see images) below, I don't know the model as it was here before me...
Deleted member 120897
I have a strange problem with my Mira Sport electric shower. When I first turn it on its hot, even at the coldest setting. I have to let it run...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
Do people with this type of mixed flow temperature control have any problems with achieving the required manifold flow temperature? The one below...
