Discuss shower pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
mak
hello guys my first post so here goes :)
im due to fit a Briston Duraspeed 70 shower pump for a customer but cant run pipework under floor to shower, so my question is:Do you think it would be ok to run dedicated hot/cold feed from cylinder and tank to pump then run the pump outlets back up the airing cupboard wall and across the loft then drop down for shower head,airing cupboard probs about 3/4metres away from bathroom.Also is a surrey flange recommended for the hot .thanks :) also what would you put the outlets in 15/22 mm
My advice is contact manufacturer's and get advice. If you fit first then get problems then its gonna be pain !!
ok thanks for the reply ,think im gonna try and persuade cust to run pipes under boards ;p
Reply to shower pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
