Discuss Shower mixer installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm fitting a shower mixer that has no means of securing it to the tile surface other than relying on the hot and cold supplies to support it.
What method of fixing would you recommend?
Normally they have a base plate that the shower fixes to
Never see on that doesn't have some sort of fixings
Plenty bar mixer fitting kits , toolstation , plumb center , screwfix etc
Not always mate. I have seen them come out the wall with 15mm x 1/2” female connectors with the threaded shower adaptors straight into these with no fixing kit at all.
Depends if it's a shower bar mixer then yes but if it's one semi built in they normally fix through the shower valve
Reply to Shower mixer installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
