Discuss Should I increase extension plumbing to 22mm in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Ive extended my house and need to run the plumbing, I will tee off from the main house which is 15mm, I'm wondering if it's worth increasing it to 22mm with 15mm tee offs to the outlets, or should I just keep it all 15mm, I'm wanting water pressure and volume to be better if multiple outlets are used. I need to run 2 sinks, electric shower a toilet and outside tap..
The extension is a self contained flat thats part of the house.
Thanks, callum
What’s the incoming water situation like as you will only get out what’s put in
Even running two outlets at the same time ?
Cold water yes hot will be fine on 15mm as you haven’t said the source and you would size the accumulator for both properties
Reply to Should I increase extension plumbing to 22mm in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
