Currently reading:
seized backnut on basin cold tap
Discuss seized backnut on basin cold tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
MORGIE
Hi Everyone,
Im needing some needing some help with a seized brass backnut on a basin tap which wont budge iv tried everything with correct tools bain wrench ect. Iv sprayed with WD let it soak but still no luck, the hot tap came off in the end but this one is doing my head in. Had my cutting disc and rotary tool ready but am wary.
Any advice would be great
Morgan
I used my Fein multi last Monday to cut one off a kitchen sink, took a while but it came off.
Won't a box spanner move it at all?
heat or cut it off and welcome to the worlds of plumbing
From the underside drill 3mm holes close together across the flange and into the nut thread.
Lightly tap a screwdriver into the holes to join them together and the nut will open out and split.
My worst was a square tap tail in a square hole on an old basin, didn't know it was square until I'd cracked the basin. To make it worse id frozen the pipe and the lost the bung :willy_nilly:
No chance of discretely moping it up as they had water sensors in the floor cavity that set off a full alarm through the building!
So don't worry, after all what's the worst that could happen?
I might try snowhead's method next time but have always cut off from above in the past.
Heating the nut with a blow lamp usually does the trick, but just be careful to use a tiny flame and not put too much heat on the basin.
Or it is a nice new steel drill bit, goggles for you eyes and drill a vertical line until little remains of the line in nut and split it with a flat screwdriver, as said above
Year ago changed my mums basin, same thing, square hole, nut wouldn't budge, brother in law tried, basin snapped in half resulting in cutting my hand & a trip to A&E
It was a nice deep sink. Pity that.
Mine was a nice old one, must have been there 40-50 years. Didn't last long after I arrived.
wonder if I could have put a round tap in that square hole - guess i'll never know:wink:
Yes you would of
As above either heat the tap up with a blow lamp, cut into the back nut or cut the top of the tap off
Might be a pita but remove the basin off the wall and work on it upside down either get a decent box type spanner or have more control over the drilling method as already mentioned.....best of luck regards Turnpin:D
Take the head off, drill with a large drill or hole cutter through seating, it will then just fall off. Round hole or square, this always works with a stuburn back nut. Good luck
Reply to seized backnut on basin cold tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
