Discuss seeking UK 40mm bath waste that will connect to 52mm hole in German steel bath in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We are buying a Kaldewei (German) steel bath, which has 52mm outlet and waste holes. Kaldewei's own (hugely expensive) waste range looks a bit iffy for connecting to normal 40mm plumbing. Has anyone done this? How did you do it? Failing that, can anyone recommend a UK, 40mm waste that will satisfactorily connect to a 52mm outlet hole. Tearing our hair out here. Any advice gratefully received Thanks
if it is an off size it should come with a reducer / it looks like some of them just accept normal 11/2 waste pipe
What is the size of a Belfast sink guy`s ? - Just wondering if it happens to suit the OP.
You won't get a plug with a bell fast
Stick with waste outlet supplied with the bath and adapt it to suit our pipe size.
Reply to seeking UK 40mm bath waste that will connect to 52mm hole in German steel bath in the Plumbing Jobs | The Job-board area at PlumbersForums.net
