Discuss seeking experienced advise on an intermittent fault on ideal logic combi? in the Gas Engineers Forum area at PlumbersForums.net
My own boiler at home has developed an intermittent fault causing an ignition lock out every week or two when there is a demand for hot water. When reset the boiler runs without issue for a week or two. This fault only occurs on HW demand, there has never been a lock out on CH demand. Ideal tech support can only advise carrying out a full strip down service, ensuring gas pressures are ok ( which I've done twice) . Any advice would be appreciated. Thanks in advance.
Does it fire and lock out or does it go straight to lockout as it's firing?
Is it always similar times. i.e first use in the day or after frequent use?
Don't get too hung up on it only apparently locking out on HW, basically your boiler is locking out every week or 2 and it may be a coincidence about the H.W
Pretty scant info so far. Just do all the basics. Check pressure drop across the system on demand. Gas rate. Flow cup. If you don't know what it is you can certainly ascertain what it isnt.
Ok. Thanks for the replies. So no fault code, just ignition lock out. It can happen at any time of the day. Now that the colder weather is here my heating is back on. Any time CH is called for or manually switched on it fires up with no issues. When the heating is running and there is a HW demand there are also no issues. Could be coincidence but it has only ever failed to fire on HW only. I don't know at what stage the lock out occurs as when it's reset it runs with no issues so I've never actually been able to witness it.
On reflection the boiler likes to initially guzzle a lot of gas to ignite. The meter governor may be sticking but I think you really should be looking at working pressures / gas rates.
Combi I take it, I have an ideal at home and had a strange issue.
I'll let u know what the issue was if you can answer the question above
Reply to seeking experienced advise on an intermittent fault on ideal logic combi? in the Gas Engineers Forum area at PlumbersForums.net
E
Have an Ideal Logic + 18 with intermittent fault. When on demand the display constantly changes from O to C but burner doesn’t start. Can fix by...
Ideal logic heat 18. Uncoded intermittent fault near end of days use only. Burner reignites every 15 seconds on and off, but no fault code...
Got up on Wednesday morning no hot water, (only cold water coming out of hot tap). Checked boiler, it had zero pressure and F1 fault showing. So I...
F
Hi, We have a new Ideal Logic Combi 30. A radiator today came off the wall and developed a leak. Plumber came and fixed (but didn't). At that...
FrankMcg
F
Hi, As per the thread title, I have an Ideal Logic Combi 30 and I am having a problem with the pump, which keeps activating without any DHW/DCH...
