Surfjayce
Ok so between the water tanks (hot and cold) and the pump itself there are quite a few compression fittings including a new cold water connector and the surrey flange. first of all i should say that non of this is fitted yet and the pump is a CT50
the fitting instructions say that no jointing compound is to be used (this is in red so I assume its warranty vital) so my question is, are compression fittings perfectly sound with no jointing compounds at all?
cheers guys
cheers guys
