Discuss rubbers washers in flexi tap connectors in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Are the rubbers washers in flexi tap connectors, usually ok at re-sealing after swapping a tap or toilet fill valve?
In a commercial setting I would offer to replace the flex's along with the taps. New washers will probably outlast the flex's.
replace the lot, only end in tears when the flexi ruptures, as you disappear in a cloud of diesel fumes
Any tips when putting the close coupled cistern back on. To mark the fixing holes. I usually tighten the wing nuts to compress the donut mark the holes undo wing nuts and take off to drill. Is there an easier way? Person before has just siliconed it
nope unless you have a friend (push down on cistern and mark holes) thats the only way unless guess like 10mm lower from full height
Can't you just drill through the fixing hole & push plug in without disassembly again?
If it was a hidden flexi yes, if it's in view, easy to get at and not damaged, not necessarily, down to personal choice and how deep the custards pockets are!
Reply to rubbers washers in flexi tap connectors in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
I have a plumber coming tomorrow to change a cartridge on a badly dripping tap on my bathroom mixer unit. There is no separate isolating valve for...
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
