I've not done a LLC for a RPH and just want to make sure I've got all the areas that need to be checked. So I'am making a check list, as I like to be as thorough as possible.
External
> LP cylinders Installed to current spec(hoses, base, resrainets etc etc)
>Test point
>ECV(Correct labeling etc)
>visual inspection of pipe work
>Base of correctly ventilated
>Ventilation not blocked
>Flue terminals
>Tightness Test
Internal
>Correct fire advice notice affixed in suitable visible location (200x130mm in size)
>Number of berths to determine correct ventilation requirements for appliances.
>Inspect ventilation & calculate to assure its correct.
>Visual inspection of visible pipework.
>visual inspection of flues
>test flues(with a match as I cant see those small flues shifting a bomb)
Appliances(too be serviced)
Service/safety inspection of Hob (Famet 4000/2) (Can get manual)
Service of water Heater (Morco D 51 B) (Can get manual)
Service gas fire (widney) (custard doesn't know what model carnaby sending me a selection)
*I like too have the manuals
The Static caravan is a carnaby siesta 26x10.
Please add anything you think may enhance my check list.
Also thank you to all previous posters for you input.
