- Messages
- 10
Rotten Cabbage Smell coming from boiler .
This is the first time I’ve signed up or posted anything like this in my life time to a forum but I am at my wits end.
So......
Rotten egg cabbage smell coming from boiler in December 2019. Thought it was gas called out cadent they got a small reading of gas and a drop of 1 bar and shut us off.
We then paid £400 for the pleasure of an emergency gas engineer to come and spray some water on the pipes under the boiler and notice some bubbling . He then tightened up the nut and was on his way .
Had our first year service with vallient in December as the boiler is brand new . Everything was fine other than he noticed a small staines from a leak inside the boiler which he thought may be coming from the flue.
Week ago we start smelling the smell again if not worse then last time so call cadent out again . Guy doesn’t get a reading from atmosphere like the last guy and only gets an increased reading around the isolation valve . No drop in bar so doesn’t shut us off . We organise valliant to come out who replace the isolation valve . He tested it before and got a lot of blips on his machine and then none after he replaced it . He noted that their had been a leak inside the boiler from the flue and it looked worse than December so he told me I need to speak to the guy who installed the boiler . At this point I thought great well the smell issue has been fixed but now I have a bigger problem of a flue leaking on to my boiler and breaking all the components .
Day after he had been the smell has now come back . Which means it was never coming from the valve at all the smell is from elsewhere . It only comes on when we are using the hot water .
Now I’ve scoured the internet for results and I will attach some comments of what other people suggest it to be but it’s like a minefield out there of suggestions. One thing I’m sure it’s not is rodent .
Can anyone come to a conclusion of what it is from my description and who should I get to come a gas safe engineer or a plumber . I’m already getting the guy who installed it to come back to sort out the leaking from the flu .
[automerge]1590615948[/automerge]
Here are some more responses
So......
So....
Can anyone come to a conclusion of what it is from my description and who should I get to come a Registered Gas Engineer or a plumber . I’m already getting the guy who installed it to come back to sort out the leaking from the flu .
