Discuss Rothenberger Rocal Pro 2 Powerflusher. Best Price Online. Next Day Delivery in the USA area at PlumbersForums.net
If not properly inhibited, central heating systems fall foul to electrolytic corrosion, scale and oxidation which gathers inside the wet system. This affects heat output, flow rate, efficiency and ultimately can lead to pinhole perforations in radiators, blockages in pipes and damage to your boiler. The Rothenberger ROCAL Pro2 Power Flusher is a very practical and easily transportable flushing solution. With ultra high flow rate, instant flow reverse and the ability to flush up to 40 radiators over three storeys. This power flusher can flush out and clean a central heating system to a very high standard which will make existing systems more efficient and meet the criteria to guarantee warranties prior to a boiler replacement. All the fixtures and fittings and all the necessary cleaning and inhibiting chemicals required for the most thorough job are supplied with every machine
Spec:
  • Motor 0.8KW
  • Tank 40 litre
  • Flow Rate 102 l/min
  • Head 20m
  • Max Temp 75C
  • Weight 21kg
  • Dims 400 x 950 x 700
  • Transport Wheels 200mm
  • Large integrated towing handle
  • Protective rubber damage cover on pipework
Supplied with:
  • 2 x 5 mtr flow and return hoses
  • 1 x 8 mtr overflow hose
  • 1 x 8 mtr dump hose
  • 1 x 8 mtr water inlet hose
  • 1 x 10pce fitting pack (does not include pump adaptors)
  • 1 x PH test kit
  • 1 x 1ltr restorer
  • 1 x 1ltr inhibitor
  • User manual
Rothenberger Rocal Pro 2 Powerflusher - https://www.corgi-direct.com/rothenberger-rocal-pro-2-18249-3424403
Reply to Rothenberger Rocal Pro 2 Powerflusher. Best Price Online. Next Day Delivery in the USA area at PlumbersForums.net
