Discuss room stats in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
Hi chaps, I got a danfoss standaRd room stat. Am not getting any audibel click when turning it up or down, when heating is on, am getting 230v at terminal 4 and . Even when I turn it up and down. Is this correct? As it is not calling for heat at wiring centre. So not getting any heating. Wires are a pickle as well.
Wiring centre
But apparently it was working ok. And then the heating would stay on with hot water but couldn't put heating on on its own. So I put new 3 port valve in and now I can get hot water on its own but not heating at all
its a take out and start again to me , bloody sparkys
It wasn't a spark it was I! Screwfix had red insulation tape on offer. I would defo strip it all back and re do all connections and clip it all back a little neater.
If its just heating u prob made minor error. Is stat a 3 wire or just live in s/l out?
So when hearing is on does vale engage / but no ignition on boiler? If so no juice getting through micro switch when 3 port swings to hearing only.
Also what boiler is it?
Is the red live when calling for heat ? Is the black live too ? What have you checked ?
Yep, am getting 240volts on on both sets of wires. But if I turn stat up or down nothing changes.
Also heating on on programmer is live. But not getting any audible click from stat
Reply to room stats in the Plumbing Jobs | The Job-board area at PlumbersForums.net
