Discuss Riser kit or plywood and 4x2 in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Matt0029
What are peoples opinions on riser kits like this? If I used one would it be best to put some 4x1 under the legs to spread the weight so it's not just on 4 points on the floor. The other option is 4x2 plywood and sand and cement
Personally hate the plinth kits they come with so I use window trim and a fascia corner which then gives me a lot more flexibility with setup height.
Stollage is better in my opinion but the legs are quicker. On the times I have had to use legs because the customer has supplied it I've put battens round the wall like you would a bath and have the tray sat on there. This makes it pretty solid
Just fitted one of these exact kits for the first time (not my choice).
Never again. Ball ache.
900 x 1200 tray. 8 legs.
Fiddly to level. The instructions say to install clips to wall, well I had 3 walls, pain the arse.
It also says to screw the feet to the floor. How exactly do I screw the back 3 feet down 850mm away from me under the tray through a 100mm ish gap?!?
4x2/ply and a bag of tile adhesive from now on.
I just tile the plinth.
Reply to Riser kit or plywood and 4x2 in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
My living room smells like a sewer but I can't tell where it is coming from. Not sure where to start looking. The saniflo discharge pipe runs...
Hi there, I'll soon be installing a SONAS 1500 X 800 resin shower tray in a bathroom that I am renovating. It does not come with any sealant or...
2K
Hi, I need some help on this shower drain installation. I’m about to install a corner shower kit in my basement bathroom. But I just found out the...
Flue Snugs Hello all new member here. Flue snugs. I’m seeing a lot of boiler installs on you tube that don’t have flue snugs to comply with...
