N
NIBob
Hi, I have a Riello RDB2 Oil Burner (120) and it has started to exhibit the oddest problem. It functions as normal in responding to signals from the Heating and Hot Water controls but I have noticed over the past number of days that it continues to run even when not being controlled by the above.
It seems to be continually heating 2 Rads that are on the primary output from the burner (these are normally heated whether you run the controls for Hot Water or Heating or both). It is running 24/7 and every now and then you can hear the burner firing up for short cycles to heat the pipes and Rads.
I have checked all controls units external to the Burner and have also replaced the Drayton programming unit as I thout this may have been faulty, it is a direct replacement but the problem persists. I am almost inclined to thing that permanent contact is being made somehwere at the Burner but I am currently at a loss.
Any help would be very much appreciated.
Darren
Darren
